FaxPress Premier WebHelp: Admin Guide > FaxPress Plus Administration > Configuring Fax Lines
Other Related Topics...
To configure fax lines from the Fax Lines folder, follow these steps:
1. Login to FaxPress Plus with Administrator privileges.
2. Select either the All Folders folder view or the Administration folder view and select the Fax Lines.
All of the fax lines configured for this FaxPress Premier server will be displayed in the right panel. The following column categories are included:
■ Fax Line
■ Fax Number
■ Status
■ Line Direction
■ Routing Type
■ PBX
■ Remote ID
■ Imprint ID
■ Dialing Type
3. Right click on a fax line and select Properties.
4. The Fax Line Settings allows you to configure the parameters for this line. Fax line settings can also be accessed through the Server Properties. See Line Settings for detailed configuration instructions.
Last Updated: 11/1/2007
E-mail this page
Castelle
855 Jarvis Drive, Suite 100
Morgan Hill, CA 95037
Toll-free 800.289.7555
Tel 408.852.8000
Fax 408.852.8100
www.castelle.com
